802.11ac bandwidth clarification
Hi all ,
AP 225 has 6 omnidirectional dowtilt antenna with 3 spatial streams . Just want to get a clarification how does it achieve 1.3gbps bandwidth . Am I ryte with the below information
3*3 antenna for both 2.4Ghz and 5 Ghz.
3 spatial streams , hence it gives 450 Mbps.
450Mbps * 3 antenna = 1.3 Gbps.
Correct me If I am wrong with the calculatio above..
Re: 802.11ac bandwidth clarification
I think you wil find most of your questions answered, and more, here...Page 8 covers your throughput questions for the 225. It's not 3*450Mbps, it has to do with channel width, QAM, etc.
Jerrod Howard
Thanks a lot...
