Moderator
802.11ac basics
The attached FAQ covers the basics of 802.11ac.  Please respond to the thread if there are any questions after reading the FAQ.
Edited: fixed a typo in Question 7 of the FAQ
Updated 5/31/2012: Updated 11ac ratification information.
Updated 6/27/2012: Fixed a broken link in the TOC and clarrified software 11ac upgrade questions.
Moderator
Re: 802.11ac basics
Great link! Thanks a lot :)
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Community Manager
Re: 802.11ac basics
All,
Just published a blog on the topic, including an interview with our in-house expert on the topic - Peter Thornycroft, aka. pthornycroft - from Aruba's Office of the CTO. Here it is:
http://community.arubanetworks.com/t5/Technology-Blog/Introduction-to-802-11ac/ba-p/21922
Super Contributor II
Re: 802.11ac basics
This fact might be misleading.
12. Will 802.11ac be backwards compatible?
Yes. 11a/b/g/n devices will be able to connect to 802.11ac radios.
I believe only 11a/n devices will be backwards compatible with 11ac radios.
Most APs will come dual band with an 11n2.4 radio for 11b/g compatibility.
What do ya'll think?
Sean Rynearson
Moderator
Re: 802.11ac basics
You are correct in that the standard for 11ac is 5 ghz only.  But when we talk with some of the radio vendors, it sounds like they will be porting some of the 11ac features to 2.4 as well.  I wouldn't be surprised if 256-QAM and wider channel bandwidths made it to 2.4 ghz.  The details are still a little fuzzy.
Even if no 11ac features make it into 2.4 ghz, the new APs would be 5 ghz 11ac and 2.4 11n.  Which means both 2.4 and 5 ghz 11n devices will be able to connect without any problems.  Existing wifi radios will continue to work on the next generation of APs.
Re: 802.11ac basics
I'm confused about the .11n backwards compatibility. Will .11n clients have to connect on 2.4ghz instead of 5ghz? It sounds like .11ac and .11n clients may not co-exist on 5ghz because of the wider channel support.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: 802.11ac basics
currently clients coexist on the 5ghz band also when there are dual channel en single channel clients, ac will just increase the number of channels you can bundle, i don't see why it would cancel eachother out.
Re: 802.11ac basics
Good point, boneyard.  I was not aware that 20mhz and 40mhz clients can coexist, so you're logic makes sense.
Re: 802.11ac basics
Can 802.11ac AP co-exist with 802.11n AP?
Re: 802.11ac basics
In FAQ#12 the 11b should be removed, 11ac works only in 5GHz.
