802.1x -Radius Auth - Band Problem
Hello ,
I have an Aruba A7005 Controller and Aruba 135 AP. I created a WLAN on controller with Radius Auth . I can connect to SSID with max 54mbs . When i change my encyription method with WPA 2 , it's running with 300 . Radius Auth. can use only WEP auth. and i can connect slowly to AP from my client. I check the bands config from controller and it seems all band. I change to A or G it's not change. It's working on 54 mbs only.
How can i configure my SSID for 300 mb or 144 mb with Radius Auth ?
Regards
Re: 802.1x -Radius Auth - Band Problem
Thats the expected behavior you can only take advantage of the 802.11n speeds if you : Open or WPA2
If you use WEP/WPA (TKIP) you will be restricted to 54 Megs
Thank you
Victor Fabian
Lead Mobility Architect
Super Contributor I
Hi!
I´ve had another customer ask this same thing. In your SSID profile under authentication you should use "WPA2" for WPA2 Enterprise (802.1X). NOT 802.1x/WEP.
Thanx,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
