802.1x bypass
Not sure if I am missing something here.  We have a handheld scanner device that I am trying to get on our internal wirless.  I tried using the User derivation rule using the mac address of the device and put it in 'Authenticated' role.  I even tried the server derivation rule with mac address.  The device does not connect.  The internal SSID setup uses certificate validation against a Windows NPS server.  I would like to bypass this if possible.  Any suggestions are welcomed.
Bill
Re: 802.1x bypass
Does the device support 802.1X?
Tim Cappalli | Aruba Security
Re: 802.1x bypass
It does.  Device has Windows CE platform on it.  Trying avoid putting a cert on it if I can...
Re: 802.1x bypass
You could configure NPS to allow PEAP as well and use a username/password on the device.
Re: 802.1x bypass
Anyway we could use User Rules to set role to authenticate?
Re: 802.1x bypass
No. You still have to pass 802.1X authentication.
Re: 802.1x bypass
Had the NPS admins add new policy for PEAP auth. New user account and password created.  All works like a champ.  Thanks for the help.
