Frequent Contributor I
802.1x or MAC authentication at same SSID
Is it possible to configure one SSID with two type of authentication?
We need 802.1x (EAP-TLS) or MAC authentication at the same SSID, is it possible to configure at 3400 controller without ClearPass?
Re: 802.1x or MAC authentication at same SSID
If you configure an SSID with 802.1x, it cannot support another device that is not configured for 802.1x.
Valued Contributor II
If you enable both MAC auth and dot1x on the same SSID, it works as follows,
1. always MAC auth first then dot1x
2. If MAC auth success and dot1x failed, user will get MAC default role
3. If MAC auth success and dot1x success, user will get dot1x default role ( or SDR/VSA role)
If you are looking for something similar, you can enable both on the same SSID.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
MVP
The kicker: the dot1x failing here means wrong password or something similar. Not a non-supplicant (dot1x) client!  Right?
So not a solution for zemarcios situation.
Koen (ACMX #351 | ACDX #547 | ACCP)
