Captive portal authentiction is not supported for an AP in bridge mode. You could still use 802.1x auth or no aythentiction (open, WPA-PSK). Split-tunnel might also achieve what you need while allowing CP auths.
That said, you might get a more usefull answer if you explain us what you are trying to achieve.
