900mbit Wireless Laptop Adapters
Hi All,
We have a couple of AP135 and want to use them to their full potential. We currently only have 300mbit compatible cards in our laptops. Can anyone recommend 900mbit cards that they have tested?
James
Cheers
James
Aruba
Re: 900mbit Wireless Laptop Adapters
I'll let others respond with client card recommendations, but the maximum over-the-air datarate you can expect from a 3x3:3 11n MIMO radio is 450Mbps (MCS23); a 50% increase from the 300Mbps you can get from a 2 stream version (MCS15).
The AP-135 is a dual radio AP, so the theoretical aggregate max is 900Mbps, but the per radio (and per client) max is 450Mbps. Note also that in most pracatical deployments, the 2.4GHz radio is limited to HT20 (20MHz bandwidth) operation, which cuts the max throughput in half.
/Onno
Regular Contributor I
Check out the following. This would only work for desktops
ASUS 4x4 802.11AC Wireless-AC3100 PCIe Adapter (PCE-AC88)
This is a 4x4 AC wave 2 adapter. This is the fastest card i have seen, but i have not personally tested it yet.
_ELiasz
ACDX, ACCP, CISSP, CWNA
