Frequent Contributor I
93H - Setting the radio
We just got 42 of the 93H access points and I seem to only have them running on the G radio.
I'm guessing I'm missing something simple, but what I have done is gone into the AP Group and unchecked the Radio Enabled on the 802.11g radio section of the group.  Is this the wrong route?  When I do this the monitoring tab shows no A channels or G channels in use, when I re-enable it the G channels re-popupate.
Any ideas?
Thanks!
Jake
Re: 93H - Setting the radio
The 93H has a single radio which can be tuned to EITHER band.  Just like the 93...
To SWITCH it from b/g to a, in the AP system profile, change the RF band to a.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for the quick repsonse, here is how it is currently setup.  I have an AP Group call SLC-NO24, and you can see the RF Band is set to a by default.  But in the AP monitor section (pictured below) it is only using b/g.  Do I need to change it somewhere else because based on what I see it should be using a band, right?
Your Virtual APs in that ap-group, what band are they set for...all? or a only...?
They are set to all.  Do I need to create a new VAP for just these APs?
Nope.  The RF Band parameter is all you should need.  What Version of Code is this?
Is this a master/local setup?  Did you click on Save Configuration or Write Mem?
- Version: 6.2.1.0
- Single controller deployment
- Configuration has been saved and no changes
Should I open a support ticket on this?
Thanks!
Absolutely.
Done - thanks for help troubleshooting.  Issues like this I always assume I've missed something.
Thanks!
Regular Contributor II
Hi Jaker.
I'm also having the same issue. The Radio only works on 2.4GHz.
Even if I have it set to "a" band. The channel always come up on 2.4GHz.
Any update from TAC?
