Frequent Contributor II
93h as Wired bridge
 I am wondering if it is possible to connect a 93h as a mesh endpoint, and give the 4 wired ports network access via the mesh connection?
Re: 93h as Wired bridge
You should be able to accomplish this .
If you already have your mesh link up and running the all you need to do is create a eth port config / wired ap and make the forwarding mode be bridge or split tunnel and apply the aaa profile with the assigned user-role already created and the VLAN those ports will use
Thank you
Victor Fabian
Lead Mobility Architect
Also would a RAP 155 be able to be converted to a CAP and be utilized in this same way?  I would love to be able to provide 2 Poe ethernet ports with a wireless backhaul for some locations.
I know the 155 can do mesh, but I don't think it can be converted to a campus AP. Only RAP or Instant.
Tim Cappalli | Aruba Security
