Super Contributor I
A mobility domain with more than 16 controllers
Hello all,
What is the problem if a mobility domain has more than 16 controllers?
I found the command “show global-user-table list” will not work.  Beside the GUT, will I have any problems with the performance of my WLAN?
(MASTER) #show global-user-table list
GUT not available if more than 16 Local Controllers are connected to the master
My AOS is 6.1.3.8
~Trinh Nguyen~
Boys Town
Re: A mobility domain with more than 16 controllers
Please open a case with TAC to understand if there are any restriction on global-user table list output.
We could also check with Engineering team on that however this shouldnt impact on any WLAN perfomance issue as such.
Thanks & Regards
Sriram Subramanian
Techincal Support Engineer
srirams@arubanetworks.com
408.585.1928
Super Contributor I
Thanks Sriram.  I got a blessing from TAC.  It should be no performance issue.  Hopefully engineer will fix the GUT
~Trinh Nguyen~
Boys Town
