AX7
A port-channel across S3500/S2500 in stack-mode
Can I configure a port-channel for uplink across S3500/S2500 in stack-mode?
Any help will be appreciated. Thanks.
Aruba
Re: A port-channel across S3500/S2500 in stack-mode
Yes you certainly can have a port-channel (aka link aggregation group) span multiple members in an Arubastack.
Take a look at the Port-Channels section of the 7.1.3 User Guide (page 105) for details on how to configure a port channel and just reference the ports anywhere in the Arubastack that you want to use.
Best regards,
Madani
AX7
Thanks Madani for your help.
That's what  I  want to know.
Best regards,
