AAA Configuration for Aruba Controller
How i can integerate my Aruba controller with Cisco Radius Server. I want the following.
There will be three users have different roles,
UserX= Predefined Rolex
UserY= Predefined RoleY
UserZ= Predefined RoleZ
how i can authorize the user from AAA for each role, can it be done with the Aruba VSA? if the Cisco AAA return me the Aruba VSA = Predefined Role, will it be assign the role to the user?
Re: AAA Configuration for Aruba Controller
Can i use the Aruba VSA = Aruba-Admin-Role on Radius which will return the value of predefined role on the controller
Which version of ACS do you have?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I use Aruba-User-Role for that, but Aruba-Admin-Role may work as well.  It works fine on ACS 3.x and 4.x.  5.x is a whole different beast and I've never used it, so I can't speak on it.
