Trusted Contributor I
ACL alias controller not working?
i might be missing something here, but shouldnt using alias controller in an ACL mean all IP adresses of the controller? if not is there a default alias i can use or should i create my own?
i wanted to restrict access to the controller for the client networks behind it, but they still can access the controller fine on the local IP of the subnet.
Frequent Contributor II
Re: ACL alias controller not working?
I guess it only translates to the controller IP address (show controller-ip) and you need to create your own aliases.
seems that way indeed, such a shame, the vrrp_ip alias does seem to be able to collect the vrrp addresses, so why not something similar for controller.
