ACL to block Wifi calling
I need to put rules to block Wifi calling(incoming/outgoing) for Iphone & anroid. Does anyone know which ports or domains I need to block to make this happen?
Thanks.
Re: ACL to block Wifi calling
Take a look at this post from last year:
https://community.arubanetworks.com/t5/Wireless-Access/Configuring-WiFi-calling-in-ArubaOS-6-5/td-p/292891
It will vary based on the service provider, so if the phone set is looking for a gateway at a specific host address, that would be the destination for your ACL.
Charlie Clemmer
Aruba Customer Engineering
