Contributor I
AIrplay after updated to OS 6
We recently updated from OS 5 to OS 6. Now airplay no longer appears to work. I cant find any settings for airgroup in the cli or the GUI. Has anyone run into this before?
Re: AIrplay after updated to OS 6
It should be there under configuration, make sure airplay is turned ON from there.
some useful commands (cli)
show airgroup status - check airplay is ON
Show process monitor statistics - to check mdns is running
Good Luck
Contributor I
I thought it should be there under advanced. Here is what I have.
could u verify from cli,
Contributor I
Airgroup is not an available option for the show command.
can u try enable airgroup from cli, or may be your software version doesnt support airgroup.
Contributor I
Airgroup isnt an option for enable. Here is the version I am running.
Airgroup is only available in ArubaOS 6.3. and above, or the technology release 6.1.3.6-airgroup (not recommended).  You will not see the airgroup commands outside of those releases.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
