ALE can not recieve RTLS
Hi Friends,
We have installed ALE and connect it with Airwave and Controller but ALE can not recieve RTLS data from controlller, we are using Remote APs on field. Do you have any idea on this issue.
Best Regards.
Re: ALE can not recieve RTLS
If you are using the AP system profile to send rtls information to Airwave, the IP address of the access point must be routable, because the rtls info comes directly from the AP. That means your ipsec pool needs to be IP addresses on a routable subnet on the controller.
