ALL WLAN Client Search Issue
Hi ,
i have a master controller connecter to 7 local controller and a Master BackUp Controller
every time i go to Monitoring>ALL WLAN Client , i Got the following error
any Suggestion or Idea
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: ALL WLAN Client Search Issue
Multiple client WLAN search is really intended to be run from Airwave across controllers for performance (took some time to search) reasons.  If you have Airwave, it is preferred to use that, as you can get up to date and historical data more easily from that platform.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
