AM not disabling N mode AP
I've got an AP 105 that I've got configured as an AM.
It seems to work great at keeping my B/G clients from connecting to a rouge AP but not my N clients.
What might I be doing wrong?
Re: AM not disabling N mode AP
I'm not sure this matters, but is High throughput enabled on both 2.4 and 5 in the radio profiles for your AM?
Zach Jennings
Perhaps my post was premature...
It does seem to be working, but it's not as quick to kill machines that have an existing connection to the rouge on N. B/G detection/protecting seemed to knock down connections to rogue APs almost instantally.
mcolwell,
Do you have the IDS/IPS (RF Protect License)?  If so, tarpitting is more effective than the standard deauth with the base license.
cjoseph wrote:
mcolwell,
I'm licensed for WIP, PEF, Next Gen PEF
mcolwell wrote:
cjoseph wrote:
mcolwell,
Okay.  First check to see what kind of wireless containment you are doing:
(orion.arubanetworks.com) (IDS General Profile "default") #show ids general-profile default
Parameter Value
Stats Update Interval 60 sec
Monitored Device Stats Update Interval 0 sec
AP Inactivity Timeout 20 sec
Adhoc (IBSS) AP Inactivity Timeout 5 sec
AP Max Unseen Timeout 600 sec
Adhoc AP Max Unseen Timeout 180 sec
STA Inactivity Timeout 60 sec
STA Max Unseen Timeout 600 sec
Min Potential AP Beacon Rate 25 %
Min Potential AP Monitor Time 2 sec
Signature Quiet Time 900 sec
Wireless Containment deauth-only  <----------------
Debug Wireless Containment false
Wired Containment false
Wired Containment of AP's Adj MACs false
Mobility Manager RTLS false
IDS Event Generation on AP none
Send Adhoc Info to Controller true
You can change that to tarpit, instead:
(3600.arubanetworks.com) (config) #ids general-profile default
(3600.arubanetworks.com) (IDS General Profile "default") #wireless-containment tarpit-all-sta
Check to make sure you changed it:
(3600.arubanetworks.com) (config) #show ids general-profile default
Parameter                               Value
Wireless Containment                    tarpit-all-sta  <-----------
 Now the AP should use tarpitting, instead of deauths.
I don't seem to have those options.
It looks like you need RFProtect for tarpit options??
If you can do this without RFProtect, what's the minimum OS you need?
Moderator
When you upgrade to AOS 6.x, the WIP license will automatically be upgraded to the RFProtect license.  You are currently licensed for WIP which means you will be licensed for RFProtect once you upgrade.  AOS 6.0 introduced a lot of new IDS features including tarpitting, a new configuration wizard, new IDS signatures, better channel scanning, etc.  I would recommend upgrading to AOS 6.1.2.7 if your controller supports it.  Legacy controllers (200, 800, 2400, sup1, sup2) do not support 6.x.  The current generation of controllers (6xx, 3xxx, M3) support AOS 6.x.
Another option to consider is enabling wired containment in addition to the wireless containment.  It will help keep the rogue device off of the network.
I'm stuck on 5.x because about 1/2 of my controllers are too old.
I'd considered pulling the old ones off my master controller and creating a second master/local system that contained just the non 6.x compatible equipment - but I don't know if it's worth the added admin time.
