Super Contributor II
AMON Firewalll reporting for bridged mode AP's
HI All,
I'm working on a client site where all the VAP's are bridged and remote over a WAN from the main array of master / local controllers at a central site.
I've enabled AMON and default amp profile (6.3.1.2) to send firewall data but i'm only seeing small trickles of info that don't seem to be representative of the actual data flows i'm expecting.
Does the fact that the AP's are running bridged VAP's result in loss of visibility of the firewall data? Do i need to use tunneled mode VAP's to get this info?
Scott
Re: AMON Firewalll reporting for bridged mode AP's
Yes, you do.
Super Contributor I
Hi!
Has this changed? Can we block and throttle applications in bridge mode VAPs?
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
This has not changed. This would best be done by an instant ap.
