Occasional Contributor I
AMP isn't connecting over HTTPS.
We are able to ping, we have DNS set up, but not able to connect over any web browser. the server is able to ping out fine, the OVA installed fine on our VMs, its just over HTTPS, we cannot connect it it.
What did we overlook?
Re: AMP isn't connecting over HTTPS.
Try running amp_enable from the CLI.
Tim Cappalli | Aruba Security
I ran it, still no response. Sorry.
Have you tried "service httpd start " ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I get this. (See file attached)
From the device you are trying to connect from, can you try to telnet to server using port 443? This will test connectivity and ensure nothing is blocking it.
That did not work. From my last post, it looks like something is wrong with the ethernet connection. Its not connecting properly, but its able to be ping-ed
Our posts crossed over the wire!
You might want to open up a TAC case. Looks like there is another service that is using port 443.
Thanks, Will do.
Moderator
I'd be interested in knowing which process is tying up the port.
Is there anything additional in the logs?
  /var/log/httpd/error_log
  /var/log/low_level_service_watcher
You may want to try the following:
1.  # amp_disable
2.  # service httpd restart
3.  # service pound restart
4.  # amp_enable
---------> this method restarts the web servers used by AMP, hopefully releasing and renewing the port.
If that doesn't work and you don't care about root cause, a server reboot would definitely do the trick to release the port for apache (may have to issue another amp_enable after a reboot).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
