Contributor II
AMP templates and IAP blacklists
          We have added several client mac addresses to an IAP blacklist that has created a mismatch on our AMP server  - is there a way to ammend the template so that it won't generate this mismatch? The AMP server is running 7.6.5 soon to be upgraded to 7.7.9.
Many Thanks
Mike
Re: AMP templates and IAP blacklists
You can navigate to the Aps/Devices -> Click on the wrench icon next to the VC.
Scroll to the bottom and click on "Import settings".
If that does not do it, then click on Audit, fetch and import the template again.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Contributor II
Thanks for the reply - sadly neither method clears the mismatch on AMP. What I really want is the command(s) I can add to the template so that it won't audit any configuration regarding the blacklist. The estate is some 8000 sites and so getting this template right is rather crucial.
Mike
in the template, do the following
blacklist-client de:ad:be:ef:ca:fe
That should do it I think
ACDX #420 | ACCA
Contributor II
Sorry for the delay - no that didn't work either , has anyone used
<ignore_and_do_not_push>blacklist</ignore_and_do_not_push>
in the template and got it working?
Regards
Mike
