MVP
ANT-2x2-2005 mounting kits?
According to the .pdf the ANT-2x2-2005 has a pole mounting kit included. Is there any info on how to mount these antenna's to the ceiling or wall or will I have to mount a pole to the ceiling/wall first? :)
Secondly.. I understand correct this reference is a kit containing 2 seperate antenna's so I'll need 2 mountingkits?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: ANT-2x2-2005 mounting kits?
You can just screw them to the AP: one on the top and one on the bottom lead of radio1.  Would that not work, or you need to mount them to the ceiling?
It is a package of two antennas.  I am attaching what is on the support website about that antenna.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
Its for use in an underground carpark, so we have the choice of either mounting everything to the very solid armored concrete supports which would block a lot of signal to certain area's OR mounting the antenna's from the ceiling with no room to stick the AP inbetween.
Anyway, with a bit of creativity mounting issues should always be solvable so we'll see what works best.
