mom
Contributor II
ANT-2x2-5314/2314 connection to AP-374
Hello!
I've got equipment from our sales team for a POC.
They gave me AP-318, AP-374 ap's and ANT-2x2-5314/2314 antennas.
They should work together, if i connect the antennas to the connectors 0 and 1.
But I'm not shure if it is necessary to terminate the 5G2 and 5G3 connectors.
This thread says that the unused connectors should be terminated with 5 ohm terminators.
Do i have to expect a loss of performance if I dont terminate the unused connectors?
Thank you!
Best regards
Matthias
Re: ANT-2x2-5314/2314 connection to AP-374
@mom wrote:
Hello!
Since this is part of a POC, I suggest contacting the sales team that provided the configuration to ensure they did not miss an item or pick up an incorrect antenna.
Charlie Clemmer
Aruba Customer Engineering
mom
Contributor II
Hello!
2x2 Antennas will work with AP-318/374, they are also listed in the ordering guide. My question was, if i have to expect performance losses if I dont terminate the unused connectors on the AP.
Thank you!
Best regards
Matthias
mom
Contributor II
Hello!
Thank you!
Best regards
Matthias
The unused ports need to have terminators installed.
Charlie Clemmer
