Frequent Contributor I
AOS 8.0.0.0 and IAP to CAP conversion
Hi All,
I'm having an issue converting an IAP 225 to CAP on AOS 8.0.0.0 7005 controller. Where is the table that lists minimum supported IAP version in case that is my problem?
The user guide says "the following table describes supported IAP platforms... " but no table is shown. See attached.
Thank you,
N
Re: AOS 8.0.0.0 and IAP to CAP conversion
225 is supported. What are the logs on the controller showing?
Tim Cappalli | Aruba Security
The logs were vague at best. I set the IAP to standalone mode, then converted to CAP. That worked.
