We recently purchased 2 - 7220 to replace our M3 controllers. I'm using the opportunity to create everything new and remove many leftovers from previous admins so basically starting fresh. My problem is currently when I make a change in the MCM it is not properly syncing to the MD. My current hang-up is on a WLAN. Using the GUI, I created the WLAN under the "Managed Network/Configuration/WLANs" selection. I originally applied Enterprise security to the WLAN created and it propagated to the MD correctly. However, for troubleshooting I changed the WLAN on the MCM to "Open", and the MD never changed to open. When I "show switches" it shows "UPDATE SUCCESSFUL". But when I "show wlan ssid-profile NAME" it does not reflect the change just made. I've performed this step a few times to see if it would pick up that change and still no change.
