Frequent Contributor I
AOS 8 Clustering and AP LACP GRE Striping
Hi Airheads,
In the 6.4 code, I had to define LACP striping IPs for my AP225's to be able to form and use LACP port channels to the upstream switch and separate out the A and G radio traffic onto separate links.
I am planning on migrating my pair of controllers to a MM-managed cluster. Is it still necessary to define the LACP striping IPs on each MD in the cluster?
