Occasional Contributor I
AOS 8 HIE SSID
Hello
SSID hide setting on AOS 8
Where is it?
I want to find out which menu the SSID profile is on.
Re: AOS 8 HIE SSID
I Check
Configuration->System->Profiles->Wiresless LAN ->SSID
Hide SSID option check
thank you
Re: AOS 8 HIE SSID
hello,
start by logging into your router’s admin panel. For me, this indicates going to 192.168.0.1 in my browser, but it could or might not be the identical for you. for example, most Netgear customers can attain it by going to routerlogin.net as a substitute. word that you may want a wired LAN connection to your router for the browser login to paintings.
seek advice from your router’s guide if you aren’t certain the way to reach the admin panel. It must look some thing like this even though:
wireless-router-admin-login
subsequent, look in the navigation bar for the wireless section. when you have submenus, look around for some thing near wireless Settings, wi-fi alternatives, wireless > basic Settings, and many others.
You have to be able to tweak the SSID, channel, channel mode, and channel width on the web page, but the critical aspect is to locate the choice called allow SSID Broadcast and uncheck it. relying in your router version, it can additionally be called Visibility repute, allow Hidden wireless, or just SSID Broadcast:
wireless-router-disable-ssid-broadcast
That’s quite a lot it. save the settings, which may or might not require your router to restart, and your router will become “undetectable” to gadgets.
regards
rajeshraj
Tutuapp Android 9Apps Android Aptoide Android
Re: AOS 8 HIDE SSID
@YOUNGLAK KO wrote:
I Check
thank you
Please make sure that both of the options below are checked:
Hide SSID: - No SSID in beacons
Deny Broadcast Probes - No SSID returned when clients probe
