Occasional Contributor I
AOS 8 multi zone giude
Hello everyone.
I know that I use the multi zone function when I use one AP in the control of each other network.
  I would like to know more about the multi zone function in AOS 8.
What configuration do you use ??
And please provide the configration guide.
Thank you.
Regular Contributor I
Re: AOS 8 multi zone giude
Hi
please find the info here :
https://community.arubanetworks.com/t5/Technology-Blog/MultiZone-with-ArubaOS-8-2-networks-for-the-price-of-1/ba-p/277104
and here :
https://www.youtube.com/watch?v=tnw-JI6AnWA
Hope this helps
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
