Frequent Contributor I
AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
Hi everyone,
I faced many issues in AOS VMC 8.2.0.2 B62929 in my Lab. I tried to install for twice.
I have 3 VLANs (1, 150, 160).
Controller IP and Mangament are in VLAN 150.
Port is Trunk and Native VLAN is 1.
AOS, AP, PEF licenses are installed. AP-325 joined the controller .
1. Module Layer 2/3 is busy. While only one client obtaining IP address from the controller act as DHCP server. For a minute, the controller reboot itself. Sometimes, it happens after use cmd #show ip interface brief.
2. I do not know that does it mean. Please see the screen capture below.
3. The controller cannot be shutdown. Please see the screen capture below.
Please help me to solve. Thanks.
Thank you,
Ratchapas S.
Re: AOS VMC 8.2.0.2 no responding, reboot itself, Layer2/3 is busy.
I would open a TAC case if this is being deployed on a supported platform. What is this deployed on, what are the ESX or KVM server specs, etc?
Jerrod Howard
Hi Howard,
I deployed on ESXi 6.0 on Nutanix.
Specs. on host
-CPU 20 x 2.799 GHz
-Memory 262 GB
-Storage a lot.
For VMC, 4 vCPU, 8GB of Memory.
Thank you,
Ratchapas S.
So you could certainly try to open a TAC case, but I don't think that would be supported or it's not something that we would have QA'd or tested. Nutanix kind of does things with it's network fabric differently than a pure ESX host, so it's hard to know if that is related to this or if it's something else. For example, if the ESX host/hardware has multiple network interconnects, those MUST be using DvSwitch and LAG (not just nic teaming) to handle virtualized network switches (which is what the controllers are), and I don't know how much of that is exposed in the Nutanix interface to be configurable.
Jerrod Howard
What Nutanix product are you running this under?
Jerrod Howard
Hi Howard,
Nutanix is hypercoverged server.
I setup this for Lab and demonstration. So I am not sure I can open case or not.
Please advise.
Thank you,
Ratchapas S.
Just to clarify - are you running this on Nutanix/VMware, or on a pure Nutanix AHV system?  I'm running the Nutanix/VMware option and it's working fine in my lab.  The AHV configuration is basically a KVM variant, though, which would put you in a totally different scenario.
It is running on VMware on Nutanix server.
Is it according to Virtual Disk Format? It is now using Thin provision.
Thank you,
Ratchapas S.
