Frequent Contributor I
AOS, bandwidth limit per SSID
Hello!
How can we rate limit traffic in SSID, or for clients that connecting to this SSID?
Thank you!
Re: AOS, bandwidth limit per SSID
- Are all users connecting to the SSID in the same role?
- Do you want the bandwidth to be a shared pool or limit each user to a certain speed?
- Do you have PEFNG?
Tim Cappalli | Aruba Security
We have 3 SSID in 1 VLAN, all users have the same role.
Want to certain speed - some like 512kb, or 1Mb...
We have only AP_upgrade_license, without PEFNG.
Thank you!
Bandwidth contracts are a firewall feature and needs the PEFNG license. You should always buy PEFNG licenses. Many features depend on it.
http://www.arubanetworks.com/pdf/products/DS_PEF.pdf
And there is no any other features?
Trusted Contributor I
there is no unlicensed feature within the ArubaOS to limit bandwidth.
