AOS point to point: Can't ping device behind point AP
Hi All,
I am trying to create a wireless point-to-point connection.
I used the template on ASE for this. Now my point to point connection is up. I am also able to ping the POINT-AP. Behind this AP is a switch, but i am unable to ping this switch. I have added the VLAN on the controller where the IP of the switch belongs to.
I think i should be very basic, but i don't see it.
Does someone has an idea?
Re: AOS point to point: Can't ping device behind point AP
Problem solved. My though was from the controller (because with an accesspoint everything is tunneled). Forgot to allow the vlans on the switch where Portal AP was connected to.
