Contributor I
AOS8 - Configure Branch controller to act like a RAP
I want to use a controller as a RAP.
The situation is like this:
We use Aruba AOS 8
We have a Mobility Master at the top.
I have a controller inside the DMZ in the main datacenter. This controller is an MD under the MM
I have added the RAP config like pools and so on.
When a use a RAP it get connected to the controller and works fine.
Now I want for another (branch) location to use a controller to act like a RAP.
What do I need to configure?
On this controller also AP’s need to be terminated and some vlan’s will be local but other vlan’s needs to be stretched to the DMZ controller.
Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE
Contributor I
Re: AOS8 - Configure Branch controller to act like a RAP
The solution is to build al GRE tunnel interface between 2 controllers (over an existing vpn). Within this tunnel, you can define what vlan needs to be transported.
