AOS8 Controller clustering problem
  • 1.  AOS8 Controller clustering problem
    Posted May 22, 2018 07:44 AM
    Hi!
    I would like to configure controller clustering in AOS8 environment, but the cluster doesn't came up.
    I manage controllers by a Mobility Master, and made everything exact like in this video, but it's not working for me.
    I must use management vlan1 now, but it's temporary.
    Mobility Master:
    (MM1) [mynode] #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.0.0.91 None MM1 Building1.floor1 master ArubaMM-VA 8.2.0.0_61883 up UPDATE SUCCESSFUL 0 21
    10.0.0.92 None MM2 Building1.floor1 standby ArubaMM-VA 8.2.0.0_61883 up UPDATE SUCCESSFUL 0 21
    10.0.0.93 None MC1 Building1.floor1 MD Aruba7030 8.3.0.0_64659 up UPDATE SUCCESSFUL 0 21
    10.0.0.94 None MC2 Building1.floor1 MD Aruba7030 8.3.0.0_64659 up UPDATE SUCCESSFUL 0 21
    Total Switches:4
    (MM1) [mynode] #show crypto ipsec sa
    IPSEC SA (V2) Active Session Information
    Initiator IP Responder IP SPI(IN/OUT) Flags Start Time Inner IP
    10.0.0.91 10.0.0.92 f8603600/2123c00 T2 May 22 13:06:03 -
    10.0.0.93 10.0.0.90 7d816f00/3090ed00 UT2 May 22 13:18:20 -
    10.0.0.94 10.0.0.90 1f852f00/74226f00 UT2 May 22 13:12:01 -
    Flags: T = Tunnel Mode; E = Transport Mode; U = UDP Encap
    L = L2TP Tunnel; N = Nortel Client; C = Client; 2 = IKEv2
    Total IPSEC SAs: 3
    Mobility Controller 1:
    (MC1) #show lc-cluster group-membership
    Cluster Enabled, Profile Name = "mc-cluster"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 50%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 30
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    self 10.0.0.93 128 N/A ISOLATED (Leader)
    peer 10.0.0.94 128 N/A SECURE-TUNNEL-NEGOTIATING
    (MC1) #show crypto ipsec sa
    10.0.0.93 10.0.0.90 3090ed00/7d816f00 UT2 May 22 13:18:20 -
    Total IPSEC SAs: 1
    Mobility Controller 2:
    (MC2) #show lc-cluster group-m
    Redundancy Mode On
    Cluster Info Table
    peer      10.0.0.93       128             N/A SECURE-TUNNEL-NEGOTIATING
    self      10.0.0.94       128             N/A ISOLATED (Leader)
    (MC2) #show crypto ipsec sa
    10.0.0.94                                 10.0.0.90                                 74226f00/1f852f00  UT2   May 22 13:12:01     -
    Total IPSEC SAs: 1
    As I see the problem is that the controllers doesn't form the IPsec tunnel that needed for the cluster operation, but don't understand why.
    Devices are in the same L2 domain, every device can reach any other in this topology. The controllers connected to the same switch by GE0/0/0 in trunk mode (native: vlan1), and the switch ports configuration are identical.
    MM: AOS 8.2.0.0-61883
    MCs: 8.3.0.0-64659
    What could be the problem?
    Thanks!
    EDIT:
    After I wrote this post, tried to configure exclude vlan1 at Mobility Master for MC1 and MC2, deploy changes, and after that I clear excluded vlans, deploy it again, and now it works! :)
    Redundancy Mode On
    Cluster Info Table
    self      10.0.0.93       128             N/A CONNECTED (Leader)
    peer      10.0.0.94       128    L2-Connected CONNECTED (Member, last HBT_RSP 44ms ago, RTD = 0.000 ms)
  • 2.  RE: AOS8 Controller clustering problem
    Posted May 22, 2018 08:53 AM
    @SkiPwrote:
    EDIT:
    Redundancy Mode On
    Cluster Info Table
    Looks like it's working for you now.
  • 3.  RE: AOS8 Controller clustering problem
    Posted May 22, 2018 10:34 AM
    Yeah, now it's working, but don't know what was the problem.
