If you work for a partner and have access to Arubapedia, it may be good to search for Workbench on there. That allows you to run remote labs even on real equipment.
If you don't work for a partner, you can work with your partner and/or Aruba SE to see if they can help you to get VMM and VMC evals for your lab.
