AP 103 console port
Hello
It seems that the new ap 103 does not have console port(or at least i dont see it on the picture of the AP 103)
but on the datasheet it says
Serial console interface (proprietary; optional adapter
cable available)
what does this mean??
Cheers
Carlos
Alternetworks Corp
Aruba
Re: AP 103 console port
Carlos,
The AP-103 does have a console port but it uses a special 4 pin adapter like the RAP-3. The SKU for the adapter is AP-CBL-SER.
Here is a underside image of the AP 103 from the installation guide.
Best regards,
Madani
The AP 103 console port is between the Ethernet and DC power port when looking at the rear. It has a plastic cover that you can just see if you look closely. The adapter is sold separately.
IT is possible to buy one and use it on different AP 103
I mean just for troubleshooting purpuses....
If i need to console it, i would go and  put the console port, and went i finish i would remove it? i mean instead of buying one for each AP.
Cheers
Carlos
Alternetworks Corp
Aruba
Absolutely, you only need to connect the adapter when you're troubleshooting and you only need one.
Madani
Regular Contributor I
while pricelist says 75dollar for this crap cable , im about to build myself like on the old AP65 with the SPOE cable , anyone has some hint which pins are connected how on that crap cable ?
i really wonder why aruba produces such a port and doesnt keep on the old-school console port style like on newer AP/RAP's ...
anyways... someone has some hint , perhaps some eBay cable which does the job ?
regards
ben
Tim Cappalli | Aruba Security
I bealive they did that to drop the prices of the APS(well one of the things they did)... why do you think the AP 103 is at that price???
Cheers
Carlos
Alternetworks Corp
did i mention AP103 is 75dollars ? im talking about the cable.
regards
I was asnwering this comment:
"i really wonder why aruba produces such a port and doesnt keep on the old-school console port style"
Cheers
Carlos
Alternetworks Corp
