Contributor II
AP-103 fitting for MNT-130?
Dear Community,
will the AP-103 fit into a mounting kit MNT-130?
The mechanism looks similar but it's not listed in the SpecSheet.
Is it just looking similar or is it really fitting?
Sven
Sven - AMFX #35
Valued Contributor II
Re: AP-103 fitting for MNT-130?
Hi Friend,
It is obsolutely possible:
For your ref :
Cheers,
Venu Puduchery,
