Contributor II
AP-105 Warm Starting
The following message is being listed consistently
05:30:09Access point 00:24:6c:c9:1a:d9 with name 00:24:6c:c9:1a:d9 and IP address 192.168.1.17 warm-started 326 time(s)
I assume the AP needs to be replaced?
Trusted Contributor I
Re: AP-105 Warm Starting
is the Instant or Controller based?
i assume a warm boot is a proces restart, there might be a valid reason for that which is not hardware related. how often does it actually happen? have you reset that AP back to factory default and get it up again? is there anything else in the logs indicating a reason?
i think the fastest way to go is try to RMA it, probably TAC will ask you some questions and determine is this is hardware related or just another type of issue.
please do report back if you try to RMA and what the resultat was.
05:30:09 Access point 00:24:6c:c9:1a:d9 with name 00:24:6c:c9:1a:d9 and IP address 192.168.1.17 warm-started 326 time(s)
You can type:
show ap debug counters ap-name 00:24:6c:c9:1a:d9
 ..and see what the nature of the warm starts are, to get an idea of what is happening.
You can also type "show log system 50" to see if the access points says why it is restarting, in addition.  The reason why an AP is restarting now and the reason why it restarted before is not always the same.  If you mounted and powered an AP before the controller was in place, it would restart quite a few times.  If the reason for it restarting is different, lately, you need to determine that to see if it is a configuration, network or a hardware issue.
Contributor II
Looks like it isn't talking to the controller. What might cause that?
AP Counters
Name               Group    IP Address    Configs Sent  Configs Acked  AP Boots Sent  AP Boots Acked  Bootstraps (Total)  Reboots  Crash
00:24:6c:c9:1a:d9  default  192.168.1.17  0             0              0              0               1          (1357 )  1357     N
Feb 2 02:44:16 :303022:  <WARN> |AP 00:24:6c:c9:1a:d9@192.168.1.17 nanny|  Reboot Reason: AP rebooted Fri Dec 31 16:05:38 PST 1999; SAPD: Unable to contact switch: HELLO-TIMEOUT. Last Ctrl msg: HELLO len=1152 dest=192.168.1.12 tries=10 seq=0
Is there a firewall or a WAN between the controller and that access point?
Contributor II
I don't believe there is.
Contributor II
I rebooted the controller to adjust the date/time and now I see these messages...doesn't look good.
2015-02-0303:58:33Access point 00:24:6c:cb:0b:2e with Name 00:24:6c:cb:0b:2e and IP address 192.168.1.17 cold-started 17 time(s)
Contributor II
Well I believe I found the issue. We have two AP's with the same static IP address...crap
and that is one of the reasons why you should use DHCP to provide IP addresses for your APs and try to stay away from static settings as much as possible. (if you can of course)
