AP-105 and 802.11N client connectivity issues.
  • 1.  AP-105 and 802.11N client connectivity issues.
    Posted Sep 04, 2012 11:54 AM
    I am having a problem with a client that has "n" capability but will only connect to my AP-105 at A/B/G (54M)
    The AP has other "N" clients associated to it so I am pretty sure that the AP is configured properly for "N"
    Can someone tell me the proper way to esnure that the AP is configured properly?
    I have ensured that both of the A & G radio profiles have High Throuput Enabled.
    Thanks.
  • 2.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 04, 2012 02:10 PM
    When you view the Monitoring --> Access Points screen, you can see what mode the two radios are in.  Check to see if the .bg HT Mode and the .a HT Mode columns are set with HT-20mhz and HT-40mhz respectively.  This will tell you that your radios are enabled for N.    Also, the LEDs on the AP will be green for each radio if N is enabled (amber if not).
    If the user still have problems, check their driver.   It may be out of date or it may be set ot use a/b/g rather than a/b/g/n.
  • 3.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 04, 2012 02:56 PM
    Thanks.
    I'll give that a try.
  • 4.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 04, 2012 09:29 PM
    Let's hope you don't have that client configured for TKIP or WEP....
  • 5.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 05, 2012 08:27 AM
    Turns out that that is the problem.
    SSID is configured for WPA/TKIP....
    Did not know that "n" doesnt play nice with them.
  • 6.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 05, 2012 11:11 AM
    Well you always learn something new.... i didnt know that either as when im configuring i alwasy put it on Arubas recommended which is AES.
  • 7.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 05, 2012 11:37 AM
    Good point.
    Thanks to everyone for their help and input.
  • 8.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 05, 2012 11:38 AM
    Use solution buttion :)
  • 9.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 05, 2012 02:46 PM
    Done.
  • 10.  RE: AP-105 and 802.11N client connectivity issues.
    Posted Sep 04, 2012 10:13 PM
    have you try upgrading the drivers of that wireless nic? it could be just an issue with the wireless card with an old driver....
    ill point more to this... i mean its with one specific client!
    Cheers
    Carlos
