Frequent Contributor I
AP-105 and VisualRF
I have a building in which I needed to install some AP-105s on the wall. Is there any way in VisualRF to properly orient these devices such that it knows it is wall mounted and in which direction it is facing?
Thanks.
Moderator
Re: AP-105 and VisualRF
Unfortunately, VisualRF can't do this yet.  This should be added into the Ideas Portal on the support website.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Ok - thanks.
