AP-105 drawing too much power
Hi Community,
Several AP-105s we have observed is intermittently drawing too much power (more than 15.4mW) and I've been trying to get as much information on how to deal about it. For now, we have to manually set the switchport power setting. What could be the possible reason why it may draw too much power? We checked the cables and they are less than 100m.
Oliver
Super Contributor I
Re: AP-105 drawing too much power
Hi Oliver,
What is the switch that you are using?
Normal Guy
We are using brocade ICX 6610-48P switches.
Oliver
Oliverm,
Please contact Aruba TAC about this issue.
As CJoseph pointed out, open a TAC case but I would be curious to know if you're 105s are in hybrid mode? Meaning do you have hybrid spectrum monitoring enabled?
EDIT: specifically on the 5ghz band
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
