AP-105 has FLAG IL after controller OS upgrade to 6.4.4.9
we have a controller 3200 running with OS version 6.3.1.23 and 9x AP-105, license installed and all working fine.
We upgraded the controller to OS version 6.4.4.9 and the APs got FLAG IL. From the output of 'show license-usage ap' it looks like no license are available.
How we can debug this issue?
Some output when we were on version 6.4:
(DEFRK2-27WC01) #show license
License Table
Key                                               Installed   Expires  Flags  Service Type
PXdGmyll-A2ekgLsr-Qr8VdlTk-LIIEU0Dl-8rwgTmCb-A9s  2013-03-19  Never     E     RF Protect: 1
                                                  19:25:49
F4JeOn2W-CbpPUXx6-rCjyB32z-gRIshUwU-G4KFh2pz-kIY  2013-03-19  Never     E     RF Protect: 4
                                                  19:26:06
F4JeOn2W-CbpybAtk-ItOh1GGg-NBb/APIq-YlnLKtuo-SeU  2013-03-19  Never     E     RF Protect: 4
                                                  19:26:23
Jb33Ypxc-cSdnF0mF-bprqFoXg-Rt07HVcV-tSMjMvHf-64I  2013-03-19  Never     E     Access Points: 4
                                                  19:26:37
Jb33Ypxc-cSdlFJBv-++ea2G53-lM8kPKr7-gmBIH+bs-oF0  2013-03-19  Never     E     Access Points: 4
                                                  19:26:47
f+uurEQK-eSiS+vRO-PsSpCyKi-NqeSkWLD-Z4NOMhto-5is  2013-03-19  Never     E     Access Points: 1
                                                  19:27:00
xHX1H/7p-W+ltVgbK-QqE+ZQda-1VCpGf5w-Cx+kJl7D-3b8  2013-03-19  Never     E     Next Generation Policy Enforcement Firewall Module: 8
                                                  21:09:29
QYLVnmB5-xEmsoFhp-Rh2wGqx+-Oh0bCtTj-tWHimP5K-Wrk  2013-03-19  Never     E     Next Generation Policy Enforcement Firewall Module: 1
                                                  21:09:29
License Entries: 8
Flags: A - auto-generated; E - enabled; R - reboot required to activate
(DEFRK2-27WC01) #show license-usage ap
AP Licenses
Type                      Number
AP Licenses               0
RF Protect Licenses       0
PEF Licenses              0
Overall AP License Limit  0
AP Usage
Type             Count
Active CAPs      0
Standby CAPs     0
RAPs             0
Remote-node APs  0
Tunneled nodes   0
Total APs        0
Remaining AP Capacity
Type  Number
CAPs  0
RAPs  0
(DEFRK2-27WC01) #
(DEFRK2-27WC01) #show ap database
AP Database
Name           Group   AP Type  IP Address     Status     Flags  Switch IP    Standby IP
DEFRK2-26AP01  DEFRK2  105      10.230.20.157  Up 1m:16s  IL     10.230.23.2  0.0.0.0
DEFRK2-26AP02  DEFRK2  105      10.230.20.82   Up 1m:15s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP01  DEFRK2  105      10.230.20.36   Up 1m:13s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP02  DEFRK2  105      10.230.20.155  Up 1m:17s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP03  DEFRK2  105      10.230.20.197  Up 1m:17s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP04  DEFRK2  105      10.230.20.188  Up 1m:17s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP05  DEFRK2  105      10.230.20.83   Up 1m:14s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP06  DEFRK2  105      10.230.20.55   Up 1m:10s  IL     10.230.23.2  0.0.0.0
DEFRK2-27AP07  DEFRK2  105      10.230.20.161  Up 1m:11s  IL     10.230.23.2  0.0.0.0
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
       I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
       X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
       R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
       c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
       u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
       i = Indoor; o = Outdoor
       M = Mesh node; Y = Mesh Recovery
Total APs:9
Re: AP-105 has FLAG IL after controller OS upgrade to 6.4.4.9
Does it work when you downgrade?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
