Frequent Contributor II
AP 105 in remote mode not working
Hi ,
I have 3200 controller with 5 AP 105 .
Currently APs in campus AP mode and working fine . I am trying to provision one AP 105 in remote mode .
I have created address pool in VPN services, added the AP in RAP whitelist but the AP is not coming up...
I tried to create a different group also , for remote mode APs that to not working
Re: AP 105 in remote mode not working
newbie wrote:
Hi ,
I could consult the "Aruba Remote Access Point (RAP) Networks Validated Reference Design" on the page here:  http://www.arubanetworks.com/technology/reference-design-guides/  It will answer the majority of your questions.
Moderator
Hi
By the looks of it you seem to have missed creating a user for your AP in the internal DB.
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Occasional Contributor I
hi, my aruba mobility controller using os 6.2.1.2 can't detect aruba ap 105. i have set remote aps managed by a mobility controller and insert the controller ip address. it keep converting for a long time. then, the controller still not showing any access point in the "ap installation".
please advise me. ty.
