Occasional Contributor I
AP 105 mode RAP --- not forward
Help, I have a controller configured on campus so I need to configure the access point model 105 in RAP mode.
I put them in the RAP whitelist, "forward mode" in ap-bridge and remote operation mode always.
When I disconnect my controller APs are active and accept connections from devices, however shortly after the free fall, as if the AP does not forward the traffic to my default gateway.
What's the problem ...
Please Help Me
Re: AP 105 mode RAP --- not forward
In the AP system profile for those access points, increase the ipsec retries from 360 to 3600, or make it zero.
Do not know if it makes a difference, but I'm using Remote Authentication Method AP certificate!
Does not make a difference.
Hi
it worked! can you explain why this configuration? Do you know of any how-to for RAP APs in 105?
:-D
IPSEC retries determines how many times a RAP will try to reach a controller before rebooting.  Zero means that it will never reboot:  It will keep on trying.
the RAP VRD is here:  http://www.arubanetworks.com/wp-content/uploads/RAPVRD_version_8.pdf?repo=tech
Thank you very much
Julio Cesar
