Frequent Contributor II
AP 105 not connecting to controller over MPLS using split tunnel mode.
I am using AP 105 for my branch office to controller connectivity. Branch office & controller connect over MPLS network.
I am using split tunnel mode to connect my branch office & AP in RAP. i have write acl to divert local traffic locally & rest of the traffic should pass over MPLS. In acl  1) wired lan subnet with source nat. 2) internet traffic & dns should go through tunnel.
But if i reconnect AP its not synchronise with controller(status down). So i try to connect using tunnel mode & its working fine.
Shall i put acl for split tunnel to communicate with controller?
Thanks in advance..
Re: AP 105 not connecting to controller over MPLS using split tunnel mode.
nikhil wrote:
I am using split tunnel to connect my branch office. i have write acl to divert local traffic locally & rest of the traffic should pass over MPLS. In acl  1) wired lan subnet with source nat. 2) internet traffic & dns should go through tunnel.
Thanks in advance..
If you are using split tunnel, you need to provision that access point as a cert-based remote AP.  Split-tunnel does not work with Campus APs.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Joseph for your suggestion.
AP in RAP mode while using split tunneling. i hv edited my post..
What is your ACL?
i hv done it by ATAC...
Split-tunnel ACL to SRC-NAT printer traffic locally and send all other traffic to the controller via tunnel.
Plz suggest me wht should i put in acl as per my connectivity and requirement.
Truthfully, if you are in your own private network (MPLS), you should just use bridged mode.  Don't bother with split tunnel.
i will try for bridge mode. But my local traffic will pass locally? or via controller. There is router at my branch location.
If it is a branch location and you use bridge mode, the traffic will use the same rules as all of the other traffic at that site, which is more efficient than tunneling it back or trying to split the traffic out.  Try bridge mode, and you will just be overlaying the traffic onto your existing network.
