AP 105 with Cisco Aironet 802.11a/b/g Wireless Adaptor
I got AP105, but i can't connect with my Cisco Aironet 802.11a/b/g Wireless Adaptor.
Is there any known issue?
Best regards,
Omer Shtivi
Re: AP 105 with Cisco Aironet 802.11a/b/g Wireless Adaptor
What encryption are you using?
wpa2 personal
Make sure you are using WPA2-AES and not WPA2-TKIP.
The key management is WPA2-psk-aes
But the adapter still can't connect
Do other clients work?
Yes,
Just a problem with this adapter.
What is the driver date on that adaptor?  Can you upgrade it?
