Contributor I
AP-105s Will Not Boot
I have received a new batch of 105 APs. I'm trying to connect them to my 6000 Controller with no joy.
They keep rebooting in a loop. This is the output from console. Posted is the last piece of information before reboot.
Testing TPM... TPM driver running in 3204 mode
i2c_adapter i2c-1: sendbytes: error - bailout.
Failed -- Rebooting
killall: nanny: no process killed
killall: sapd: no process killed
SIOCSIFADDR: No such device
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
Restarting system.
Any Ideas?
Ian
Contributor I
Re: AP-105s Will Not Boot
Hmm I should probably do my research beforehand.
Found another post with this information and it looks like they need to be returned...
Make sure that the APs are able to get a valid IP and that they can reach controller using ports 8211/47
How are those APs reaching the controller: DNS, DHCP option 43, ADP ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
There is an issue with the AP
You need to open a support case with the TAC
Also before that check out if this isnt your issue... read the document im attaching you...
Cheers
Carlos
Alternetworks Corp
Contributor I
Yep thats most likely the issue, the APs are newer than the listed serial numbers and my controller is 6.1.2.5.
I will upgrade test
Many thanks for the help
