Re: AP 115 vs 105 vs 135
yes they are unfortunately.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Thoughts? I've been looking at this a little further and client goodput is ok. Channel utilization is anywhere between 2-12% but this could be because of usage (client aware is on).
Thinking of disabling b basic rates from what I see from airwaves reporting not much b going on or at all.
Still waiting on pricing for 115s but definitely thinking moving the aps out of the drop ceiling and mounting them on the the t-bars along with changing to 105 or 115s would greatly benefit the customer
ACDX #420 | ACCA
MVP
FYI: a colleague did a quick test in our underground parking garage and got a substantial improvement in coverage going from AP-105 to AP-115. He only tested 2.4GHz though. :smileymad:
And yes, there are plenty of situations where coverage is far more important than density.
Koen (ACMX #351 | ACDX #547 | ACCP)
Aruba
Koenv,
Tell us more on the results and the test conditions used when you can... agreed on the 2.4 GHz only piece ;(
I'll be curious as to what kind of tests you guys typically do when comparing this kind of stuff.
JF
Aruba
BTW, the pricing on the AP-115 is $895 USD  aka.  +$200 USD LIST over the AP-105  and -$200 USD LIST under the AP-135.
Aha, right in the middle.  I think someone above described it as a 'sweet spot'.  Oh yeah, i remember who ;-)
JF
was you!
Question: What amount of users can each AP support?
I know this depends on network and type of clients but are there any numbers?
105: 20-25 users per radio??
115: 30-40 users per radio??
135: 40-50 users per radio??
For example..
ACDX #420 | ACCA
This thread has fizzled out a bit but I'm currently in the same predicament here as well
I currently have AP-105's and for reasons I don't want to get into here, we are looking at upgrading to AP-115 or 135 Maybe?
We are a school with 1 to 1 ipad program with an AP 105  covering in each classroom
We have approx 25 + iPads/devices in each classroom...
Would the AP 115 be sufficient?  from my reading the 115 is for better "coverage" and the 135 for better "density"
I don't think we'll go over 30 devices on one classroom at a time.
Your prompt response is greatly appreciated.
Jef
Access point information is very fragmented and that's why I made an "Aruba access point portoflio overview", based on the datasheets and practical use. An one-page file which gives you an instant non-cluttered overview of the current Aruba portfolio (Indoor and internal antenna's only).
PDF: goo.gl/sl34HV
Feedback appreciated
Useful post? kudos appreciated!
srfrdrew, the 115 will certainly handle 30 iPads on a single AP, esp if you are doing it now with the 105s. The 115s have more CPU and better radios.
Jerrod Howard
