AP-124 5VDC Input
Can anyone tell me the current draw using the 5VDC input power connection.
Also what is the type of connector used?
I am trying to power this and another device using a PoE splitter.
Aruba
Re: AP-124 5VDC Input
Worst case DC power consumption is about 15W, so you'll need 3A.
Voltage needs to be 5V +/- 5%
Mechanical specs for the plug: circular center positive 5.5/2.1mm, 9.5mm long.
Hope this helps.
/Onno Harms, Aruba
/Onno
Yes it did Thank you
