Contributor II
AP-125 and AP-135 Mixed environment
If I had a building with a mix of AP-125s and AP-135s, would clients be able to roam from an AP-125 to an AP-135 without issue?  I would guess that there shouldn't be since they are both 3x3, but I just want to make sure.  Thanks for your time.
Frequent Contributor II
Re: AP-125 and AP-135 Mixed environment
[ Edited ]
It works fine.
Contributor II
Thanks for the info.
