AP 125 as an Air Monitor doesn't block interfering AP after controller upgrade 6.1.3.7
  • 1.  AP 125 as an Air Monitor doesn't block interfering AP after controller upgrade 6.1.3.7
    Posted Oct 28, 2013 06:53 PM
    We have a custumer who had some AP 125 Air Monitors that works fine to block interfering SSIDs in 5.0.3.1 AOS version. When he purchased new 135 APs, we upgrade the controller to 6.1.3.7 in order to use these new APs. When we test the discovering/blocking function of the AP 125 Air Monitors, we note that does not work these APs, it takes too much or these APs can't discover the interfering SSIDs, and when these APs discover the SSID, these can't block the SSIDs.
    Are there some recommended RF configuration to remediate these issues?
    Thanks in advance.
    #AP135
  • 2.  RE: AP 125 as an Air Monitor doesn't block interfering AP after controller upgrade 6.1.3.7
    Posted Oct 28, 2013 06:58 PM
    Can you please share the IDS configuration for the Air Monitor AP-Group
  • 3.  RE: AP 125 as an Air Monitor doesn't block interfering AP after controller upgrade 6.1.3.7
    Posted Oct 29, 2013 12:19 PM
    I'm waiting for remote access with the costumer to copy the configuration. It shoulbe mentioned that the APs 135 work correctly for interfering SSIDs discovering and blocking, despite the APs 125 don't. Thanks.
